HTML to PDF Table of contents
I am trying to add a table of contents in a PDF while converting from HTML to PDF. This will only work if I add to param.pyPDFHeaderHTMLTemplate and Call HTMLToPDF.
If I set this value in the markup or stream name, nothing gets generated.
I can not have this in the header as I do not want this to get generated on all pages.
I am used PD4ML <pd4ml:toc> inside of the Markup HTML
