Issue in getting html table in RTE
Iam trying to get the HTML content in rich text editor for which i created html rule and done the property-set-html to set the html stream to a property and doing a show-property method and calling the activity in javascript to set the content in RTE on click of plugin i added.
But all i can see in the RTE is all tags i added to html rule,that is it basically rendering the whole html code into RTE rather then showing the content in html table format .
One thing i observed is when i click on the source button on RTE ,the code appears with in <pega:reference name=" > tag and if remove this tag the content got rendered into proper html format that is in the expected format as you can see in attached snapshot.
Please find snapshots i attached for further reference.
Please help me fix this issue.
Thank you ,
Abdul Sofiyaan.
