Issue
Results are not displayed on touch-enabled devices on selecting the down arrow key in the Multi-select list configuration pane. The problem does not occur if you use a mouse to select the down arrow.
Steps to reproduce
Perform the following steps to reproduce this error:
- Open the harness or section that you want to modify.
- On the Design tab, from the Pickers list, drag Multi-select list onto the work area.
- Open the Multi-Select list configuration pane and click the down arrow key under the List source Type option.
Root Cause
An error in Pega’s code removes a required target element in the pzpega_control_multiselect js function.
Solution
Update to the following Pega Platform versions with the fix:
- Pega Platform™ 23.1.2
- Pega Platform 23.1.3, see Pega Platform 23.1.3 Patch Resolved Issues.
- Pega Platform 24.1.1
Environments
Versions found in:
This problem was reported in the following Pega Platform versions:
- Pega Platform 8.8.4
- Pega Platform 8.8.5
- Pega Platform 23.1.1
- Pega Platform 23.1.2
- Pega Platform 24.1.0
Versions fixed in
This error was fixed in the following Pega Platform versions:
