Corebridge Financial
Last activity: 9 Jan 2025 10:34 EST
Pega application login JMeter script fails with 403 Forbidden error
I'm working on performance testing a Pega application using JMeter. The JMeter script fails at login (Non SSO) at page /prweb/PRServlet/app/il-cc/********/!STANDARD with Error 403 Forbidden. I have captured dynamic values pzHarnessID and pzCTkn in script and using them. I see one more dynamic value pzBFP in header which I'm not able to capture as it seems to be generated by client side javascript. I suspect this is the one causing the request to fail but I might be wrong too. Has anyone come across similar issue handling pzBFP or any other work around you would suggest? Appreciate any help on this
John
