Societe Generale
Performance Testing
Hi Team,
Did anyone tried with Jmeter for performance testing on Pega. we are facing issues with login to the application
Swedish Unemployment Funds
SE
Was I while ago I did it but if I remember correct I had to use netscape cookie policy in the http cookie manager when upgrading to Jmeter 3.x. Also hade to use the JVM http implementation (HTTP request defaults -> Advanced -> Implementation: Java) instead of the standard Apache HttpComponents HttpClient 4.x.
Also you probably need to extract the accessgroup when posting login, and in the flows you also need the pzTransactionId to keep state between pages.
JMeter has been used extensively in Pega Engineering internally. What specific errors are you getting (with more details/screenshot so that we can help you better)?
Express scripts
We are similarly using Jmeter for our Loading testing a pega application and we are facing login issue. We are getting 500 Internal server error. In short it is redirecting to login page after providing valid credentials.
And we are able to proceed with Load runner but we want to migrated to Jmeter.
Appreciate your help.
PT Bank Sinarmas
ID
Hi Kevin zheng,
Could you share me how to use jmeter for Pega testing ?
I already explored and asked PDN about one week, but still confuse how to use jmeter for Pega testing.
Brgds,
Dendi A
Syn
Did you got answer for this. we are using Jmeter for pega performace testing. Let me know if you need any information.
Hello @Naveens2739,
Have you tried out the solution in the pinned reply marked as Correct Answer?
Coforge
Any resolution the above issues of login..please help. We are also getting 500 Internal server error while logging in. But the subsequent requests are working fine and it happening for Pega 7.3 version.
Hello!
In case you're still facing this issue, please go ahead and create a new post by clicking the Write a Post button on the right pane above!
SE
Coforge
Thank you..it worked:-)
PT Bank Sinarmas
ID
Could you share the tutorial using jmeter for pega system ?
Brgds,
Dendi A
