MBAFC
CN
Last activity: 19 Jun 2024 1:48 EDT
Question about best practice on basic access control
We plan to upgrade CustomerServiceForFS 8.2.8 to CustomerServiceForFS 8.23.1 or later.
Currently we facing the issue 403 which result by the new feature basic access control.
Our plan is to update our code to mitigate the 403 issue. However there are some security event SECU0019 were found in the security event log which result by the Pega OOTB rules.
For example:
Issue 1: which was resulted by the rule webwb • Pega_interaction_commonUtil • js. And this rule is a final version created by Pega.
https://support.pega.com/system/files/attachments/question/2024-06/BAC%20Issue%201.PNG
Unauthorized request detected : Unregistered request encountered with params pyActivity:pzRunActionWrapper pySubAction:runAct pzActivity:PegaCA-Work-Interaction.PopulateHarnessPage e
Issue 2: similar as issue 1 which was captured the error when use the scenario test record. This issue also result by the OOTB rule and that is a final rule.
https://support.pega.com/system/files/attachments/question/2024-06/BAC%20Issue%202.PNG
Unregistered request encountered with params pyActivity:pzRunActionWrapper pySubAction:runAct pzActivity:pxCreateFunctionalTestCaseStep eventSrcSection:Rule-Test-Functional-Case.pxAutomationRecorderFooter*
If we want to enable the new BAC feature, what we should do to resolve the issue caused by the Pega OOTB rule.
For example:
