Cap Gemini
DE
Last activity: 12 Jun 2024 10:46 EDT
Custom parameter prompting appears read-only
Hi all,
We are implementing a flow, which can be added from App Studio. This flow runs a custom integration. So the citizen developers can pick this flow as a smart shape.
We have implemented a custom Flow Action, so that when citizen developers select this flow, they can configured it, using this Flow Action.
Now, when we select this Flow, the Flow Action appears as Read-only. I tried and force all controls (using a template with Cosmos) to be editable but still all fields appear as read-only.
The section appears at first editable, but then refreshes and then goes read-only (both on Dev Studio and App Studio).
We did not set privileges neither on the Flow, neither on the Flow Action. When we trace it, no errors. Nothing on the logs either.
I followed the steps described in this link: https://docs-previous.pega.com/process/how-create-custom-smart-shape#create-section-and-flow.
The Flow Action has a Post Data Transform, to set the flow parameters from the properties on the Flow Action / Section (as described in the link above).
