Cognizant
Last activity: 4 Jun 2024 13:46 EDT
Connect soap: Connection idle timeout
Hi all,
Configured a new connect soap service in my application. When make a call from source to destination out of 10 calls, 4 to 5 calls are falling. we didn't receive any response from the destination. Application we are using is in Pega6 version.
In logs can see the below exceptions.
failed:PRRuntimeError:com.pega.pegarules.pub.PRRuntimeError: PRRuntimeError
Caused by: com.pega.pegarules.pub.services.ResourceUnavailableException: SOAP service failed
Caused by: java.net.SocketException: Connection reset
In connect soap setting increased the Response timeout 2min to 5min. Still facing the same issue. Is there any way to get a rid of this issue by doing any changes at connect soap settings/activity in code level?
Got to know from suggestions, needs to minimize the connection Idle timeout to 20 to 30 seconds. if this is the solution, where can I do these changes in Pega code level?
Can you please someone help on above asking questions?
Subhashini.
