SOAP: How do I retrieve the entire contents of the SOAP XML message for the Fault and the Response?
I have a generated SOAP service. Everything is working fine.
What I wanted is to be able to retrieve the entire contents of the SOAP XML message for the Fault and the Response?
From the help, it was mentioned that the Target Property: "...store the entire contents of the SOAP envelope that contains the fault/response message."
Interestingly, for the Faults tab, it was preset as ".pySOAPFault", and I would expect to be able to access this value in the generated SOAP Response DT. I have purposely generated a SOAP fault and able to see the pyErrorPage in the output of the generated DPage. However, I had tried different ways to access this property, but it is always blank, it is also not even in the tracer at all.
Can someone advise:
1) Where exactly can I access this ".pySOAPFault"?
2) Can the Target Property points to a property on a clipboard page? I had tried this, although I can save the rule, it also displayed a blank value.
Thanks and looking forward to any advice.
Jacky
