Accenture
Last activity: 14 Feb 2017 8:19 EST
Pega 7.2.1:Connect-SOAP timeout is not working
We are on Pega 7.2.1, soap connector is not timing out per the value configured in response timeout field in Connect-SOAP rule form when connecting to a valid endpoint URL when service is not available.
Although response timeout is set on a Connect-SOAP rule, but the connection times out after longer duration than the set timeout value.
Can some one help here? Attached document for details with screenshots.
Hi Hari,
Please refer the below link. Similar issue and explanation for the same is provided in the link.
https://collaborate.pega.com/question/pega-721connect-soap-timeout-not-working
Accenture
I have referred above article. But no use. It mentioned that "Valid URL - Connection is established and service is sending some response – In this case the connection will timeout per configured value on rule form if the service does not respond within configured time." But in my case it is not working. It is still taking more time than what i have define in Connect-SOAP rule. Please refer attached document for details.
--Adding the update for wider audience--
Hi Hari,
As mentioned in the PDN article, this system behaves in two different way when setting the response timeout lower or higher to what the server respond.
With the Response Timeout of 30000; the service recognize that:
2017-02-07 17:35:42,139 [ http-apr-80-exec-19] [TABTHREAD1] [ ] [hiftMgmtWeb:01.01.01] (lient.params.DefaultHttpParams) DEBUG Rule-Connect-SOAP.TNSW-Roads-SMFE-Int-SOAP-ShiftMgmtService.VerifyROLRequest mindaguh - Set parameter http.connection-manager.timeout = 30000
But after 21 second, the services respond with an error:
2017-02-07 17:36:03,143 [ http-apr-80-exec-19] [TABTHREAD1] [ ] [hiftMgmtWeb:01.01.01] (.httpclient.HttpMethodDirector) INFO Rule-Connect-SOAP.TNSW-Roads-SMFE-Int-SOAP-ShiftMgmtService.VerifyROLRequest mindaguh - I/O exception (java.net.ConnectException) caught when processing request: Connection timed out: connect
The default behaviour in this case, with timeout set on rule form being more that 21 seconds is to retry 3 more times; this is what actually happened:
Attempt 2:
Hi Hari,
Attempt 2:
2017-02-07 17:36:03,143 [ http-apr-80-exec-19] [TABTHREAD1] [ ] [hiftMgmtWeb:01.01.01] (.httpclient.HttpMethodDirector) INFO Rule-Connect-SOAP.TNSW-Roads-SMFE-Int-SOAP-ShiftMgmtService.VerifyROLRequest mindaguh - Retrying request
2017-02-07 17:36:03,143 [ http-apr-80-exec-19] [TABTHREAD1] [ ] [hiftMgmtWeb:01.01.01] (.httpclient.HttpMethodDirector) DEBUG Rule-Connect-SOAP.TNSW-Roads-SMFE-Int-SOAP-ShiftMgmtService.VerifyROLRequest mindaguh - Attempt number 2 to process request
Then ERROR AGAIN:
2017-02-07 17:36:24,148 [ http-apr-80-exec-19] [TABTHREAD1] [ ] [hiftMgmtWeb:01.01.01] (.httpclient.HttpMethodDirector) INFO Rule-Connect-SOAP.TNSW-Roads-SMFE-Int-SOAP-ShiftMgmtService.VerifyROLRequest mindaguh - I/O exception (java.net.ConnectException) caught when processing request: Connection timed out: connect
Attempt 3:
2017-02-07 17:36:24,148 [ http-apr-80-exec-19] [TABTHREAD1] [ ] [hiftMgmtWeb:01.01.01] (.httpclient.HttpMethodDirector) DEBUG Rule-Connect-SOAP.TNSW-Roads-SMFE-Int-SOAP-ShiftMgmtService.VerifyROLRequest mindaguh - Attempt number 3 to process request
ERROR AGAIN:
2017-02-07 17:36:45,151 [ http-apr-80-exec-19] [TABTHREAD1] [ ] [hiftMgmtWeb:01.01.01] (.httpclient.HttpMethodDirector) INFO Rule-Connect-SOAP.TNSW-Roads-SMFE-Int-SOAP-ShiftMgmtService.VerifyROLRequest mindaguh - I/O exception (java.net.ConnectException) caught when processing request: Connection timed out: connect
Attempt 4:
2017-02-07 17:36:45,151 [ http-apr-80-exec-19] [TABTHREAD1] [ ] [hiftMgmtWeb:01.01.01] (.httpclient.HttpMethodDirector) DEBUG Rule-Connect-SOAP.TNSW-Roads-SMFE-Int-SOAP-ShiftMgmtService.VerifyROLRequest mindaguh - Attempt number 4 to process request
Return failure:
2017-02-07 17:37:06,155 [ http-apr-80-exec-19] [TABTHREAD1] [ ] [hiftMgmtWeb:01.01.01] ( internal.mgmt.Executable) ERROR Rule-Connect-SOAP.TNSW-Roads-SMFE-Int-SOAP-ShiftMgmtService.VerifyROLRequest mindaguh - Exception
com.pega.pegarules.pub.services.ResourceUnavailableException: SOAP service failed
at com.pegarules.generated.activity.ra_action_invokeaxis2_4054e98ba19df03aff55083d242bbf9d.step15_circum0(ra_action_invokeaxis2_4054e98ba19df03aff55083d242bbf9d.java:4017)
at com.pegarules.generated.activity.ra_action_invokeaxis2_4054e98ba19df03aff55083d242bbf9d.perform(ra_action_invokeaxis2_4054e98ba19df03aff55083d242bbf9d.java:308)
at com.pega.pegarules.session.internal.mgmt.Executable.doActivity(Executable.java:3527)
at com.pegarules.generated.activity.ra_action_invoke_8171c74e56fb26f2c41f9a69e39e4099.step8_circum0(ra_action_invoke_8171c74e56fb26f2c41f9a69e39e4099.java:1037)
at com.pegarules.generated.activity.ra_action_invoke_8171c74e56fb26f2c41f9a69e39e4099.perform(ra_action_invoke_8171c74e56fb26f2c41f9a69e39e4099.java:189)
at com.pegarules.generated.activity.ra_action_invokeverifyrol_1378aac81270d0fe3bac40749d619d52.step4_circum0(ra_action_invokeverifyrol_1378aac81270d0fe3bac40749d619d52.java:468)
at com.pegarules.generated.activity.ra_action_invokeverifyrol_1378aac81270d0fe3bac40749d619d52.perform(ra_action_invokeverifyrol_1378aac81270d0fe3bac40749d619d52.java:134)
In this way the timeout is returned after more than 30000ms, which totals to about 84000ms.This concord with your observation and is completely as per system design.
Atos
How to find out that our pre-prod environment uses the standard tomcat configuration where Tomcat’s internal web server is used.
Thanks in advance.
Hi Dipak,
I believe this is an duplicate entry of the below post.
https://collaborate.pega.com/question/how-find-out-tomcat-configuration-our-environment
Hi Hari,
Attempt 2:
Hi Hari,
Attempt 2:
Then ERROR AGAIN:
Attempt 3:
ERROR AGAIN:
Attempt 4:
Return failure:
