atos
Last activity: 10 Jan 2024 10:40 EST
Control mismatch issue
We are facing a control mismatch issue for an oracle form control. It is matching in our local machine but failing in PROD VM.
We checked the IE version is different but the java version is still same.
Please tell if this difference is impacting us or there can be some other underlying issue which needs to be looked after.
The match rules used are sequence match rule and position match rule. As mentioned earlier the control matches in local machine but fails in PROD VM.
***Edited by Moderator Rupashree to add Capability tags***
