pega constellation api error response status is 401
hi
im trying to learn about pega constellation but when try to go to api page and test it give me 401 error and also i get the same error when i run the sdk
hi
Hi @HashimB
can you please attach screenshots of the error for SDK and API.
Please check the authentication, API is failing due to Unauthorized access
can you please check the API of the service package where you need to know the Authentication Type and try to access with that type, like if it's an OAuth 2.0 then you should access the client details or For Basic authentication, you need to provide the Operator ID and Password.
For SDK can you please refer to the installation guide that pega provided.
@PPRANEETH007 im trying to add an attachment on my post but i cant there is error with ( ops something wrong )
and about my question
yes im using OAuth 2.0 and im using the right details for client
Hi @HashimB
Have you configured in the SDK? and can you please give the password in base64 in sdk and if possible please try to attach the screen shots as well.
Thank you
Praneeth
yea i configured in the sdk and also i give the sdk base64 password
