How to list Case instances exported with BIX Extract rule into XML file
Hello!
The Context:
I use BIX Extract rule to export case instances. I export them into an XML file and not a database table. The export process is triggered in an Activity via the pxExtractDataWithArgs activity with parameters. The cases can be exported based on pyID or a range of pxUpdateDateTime. For reporting I use the Log-Extract class to retrieve information about the export. However, these instances have only high level information.
The Requirement:
After the case data extraction happened, I would like to know what were the cases successfully extracted and what are the ones that had error during the process.
Question:
Is there any option to retrieve a list of Case IDs or Instance Keys that were extracted to the XML file?
Thanks!
***Edited by Moderator Rupashree to add Capability tags***
