How to add user defined pyWorkPage property in pxUrgencyAssign declare expression to get priority in Getnext work
How to add user defined pyWorkPage property (Days remaining 30 is max and it will reduce by 1 every day) in pxUrgencyAssign declare expression to get priority in Getnext work. This criteria should be along with default existing pxUrgencyAssign.
For example: I created case today and max days remaining is 60. Tomorrow max days remaining property value is 59 and so on. When ever user performs getnext case , criteria should be checked is which ever case has less number of days to work should be fetched to user to work.
If more cases has same number of days then it should check urgency on case to determine the next case.
Please let me know how to implement this logic in GetnextCase. What changes i need to make at pxUrgencyAssign declare expression. If not let me know where to update this logic in Getnextfunctionlity.
