Publicis Sapient
Publicis Sapient
Publicis Sapient
Posted: Nov 24, 2023
Last activity: Dec 24, 2023
Last activity: 24 Dec 2023 2:36 EST
How to remove idle or expired Requestors from Nodes
Hi Team,
I am looking some suggestions on how to cleanup the idle or expired requestors specifically Batch which were created by background processors from All nodes.
The requestors are idle and consuming some memory. we need to cleanup this idle requestors and clear memory.
Is there any OOTB background processing rules that can cleanup ?
@Shaik Muzammil In Pega, Batch requestors created by background processes like Queue Processors, Agents, Job Schedulers, DataFlows etc., are not automatically cleared up. They are reused and will be put back to the pool for later reuse. They are removed only when the node gets restarted.
There is no Out-Of-The-Box mechanism to automatically clear up the aged and stale requestors.
However, you can manually clean up the tables if needed. Please note that removing requestors and pages that are newer may lead to an increase in passivation errors in the logs and is generally not recommended for a user's best experience.
This is a GenAI-powered tool. All generated answers require validation against the provided references.
Session Management Troubleshooting FAQs
Requestor Management Troubleshooting FAQs
If you encounter an issue that needs to be investigated in-depth I recommend that you log a support INC via the MSP.
