LTIMindtree
Last activity: 5 Nov 2023 22:38 EST
PEGA OOTB pxAssignDateTime property UI control resulting dat time format exceptions
Hi Team,
We are using pega property from assign worklist and assign workbasket to display the assigned to date column using pxAssignDateTime property in 10/13/2023/ 06:19:39 format.
While converting to this format system is throwing some exception in logfile due to the OOTB property UI control.
Please find the exception triggering
M021211 - Cannot create format " datetime_default", default format is used M021211 - Cannot create format " datetime_full", default format is used M021211 - Cannot create format " datetime_medium", default format is used M021211 - Cannot create format " datetime_short", default format is used M021211 - Cannot create format " datetime_2yshort", default format is used
Property UI control:
pxAssignDateTime DateTime-Medium
format to be displayed in UI:
did anyone come across this scenario, how to avoid these exceptions on the log file.
Thank you
