Declare Index issue after Pega upgrade
Yesterday we had Pega Upgrade in production and found couple of observation/exceptions which we didn't face in stage environment .
when upgrade is done ,after couple of hours we see lot of entries in index tables (Rule-Declare-Index) and all are duplicated (unfortunately no primary key on these index tables) also it happened for all resolved cases.
Not sure which event/action triggered this reindexing part as part of upgrade
Sharing few logs below but attached the complete log file and look at timestamps between 2023-06-27 15:08' AND '2023-06-27 16:49')
Attachment table:-
Attachment table:-
2023-06-27 15:09:13,633 [cols-AsyncExecutor-3] [ STANDARD] [ ] [ ] (writers.ScalarPropertiesWriter) INFO - Saving with updated declarative index information: DATA-WORKATTACH-FILE MyOrg-MyAPP-WORK L-94364!20191126T124825.221 GMT 2023-06-27 15:09:13,638 [cols-AsyncExecutor-3] [ STANDARD] [ ] [ ] (ols.readwriters.MaxIndexWriter) INFO - Max Index [-99999] < 0 # Resetted Top Index [0] # DATA-WORKATTACH-FILE MyOrg-MyAPP-WORK L-94364!20191126T124825.307 GMT has indexes exists but has no 'pzIndexes' property. 2023-06-27 15:09:13,666 [cols-AsyncExecutor-3] [ STANDARD] [ ] [ ] (writers.ScalarPropertiesWriter) INFO - Saving with updated declarative index information: DATA-WORKATTACH-FILE MyOrg-MyAPP-WORK L-94364!20191126T124825.307 GMT
Work Table
2023-06-27 15:09:39,482 [cols-AsyncExecutor-1] [ STANDARD] [ ] [ ] (writers.ScalarPropertiesWriter) INFO - Saving with updated declarative index information: MyOrg-MyAPP-WORK L-107906 2023-06-27 15:09:39,485 [cols-AsyncExecutor-1] [ STANDARD] [ ] [ ] (ols.readwriters.MaxIndexWriter) INFO - Top Index [5] > Max Index [4] MyOrg-MyAPP-WORK L-107907 2023-06-27 15:09:39,487 [cols-AsyncExecutor-0] [ STANDARD] [ ] [ ] ( internal.mgmt.Executable) ERROR - Only authenticated client may start this activity: RULE-OBJ-ACTIVITY RULE-OBJ-REPORT-DEFINITION PXRETRIEVEREPORTDATA #20220919T124254.899 GMT ReqID=BUBNXJNP1KBIU4RT3UNV8AI4ZQ0II374FA com.pega.pegarules.pub.PRRuntimeException: Error: You lack access required to execute RULE-OBJ-ACTIVITY RULE-OBJ-REPORT-DEFINITION PXRETRIEVEREPORTDATA #20220919T124254.899 GMT. at com.pega.pegarules.session.internal.mgmt.Executable.updateStepStatusAndLog(Executable.java:1086) ~[prprivate-session.jar:?] at com.pega.pegarules.session.internal.mgmt.Executable.updateStepStatusAndLog(Executable.java:1076) ~[prprivate-session.jar:?] at com.pega.pegarules.session.internal.mgmt.Executable.activityProlog(Executable.java:923) ~[prprivate-session.jar:?] at com.pegarules.generated.activity.ra_action_pxretrievereportdata_4487983b09d377f8f24eebaf846a174f.perform(ra_action_pxretrievereportdata_4487983b09d377f8f24eebaf846a174f.java:59) ~[?:?] at com.pega.pegarules.session.internal.mgmt.Executable.doActivity(Executable.java:2872) ~[prprivate-session.jar:?] at com.pega.pegarules.session.internal.mgmt.Executable.invokeActivity(Executable.java:11502) ~[prprivate-session.jar:?] at com.pegarules.generated.activity.ra_action_pxcallretrievereportdata_f81870511486f400512ef7cfa98f9945.step5_circum0(ra_action_pxcallretrievereportdata_f81870511486f400512ef7cfa98f9945.java:492) ~[?:?] at com.pegarules.generated.activity.ra_action_pxcallretrievereportdata_f81870511486f400512ef7cfa98f9945.perform(ra_action_pxcallretrievereportdata_f81870511486f400512ef7cfa98f9945.java:147) ~[?:?] at com.pega.pegarules.session.internal.mgmt.Executable.doActivity(Executable.java:2872) ~[prprivate-session.jar:?] at com.pega.pegarules.exec.internal.declare.infengine.pages.DeclarativePageDirectoryImpl.runRule(DeclarativePageDirectoryImpl.java:1780) ~[prprivate-exec.jar:?] at com.pega.pegarules.exec.internal.declare.infengine.pages.DeclarativePageDirectoryImpl.runLoadActivity(DeclarativePageDirectoryImpl.java:508) ~[prprivate-exec.jar:?] at
