model dialog box submit button not working
my model dialog box submit is not working.
this model call in flow action
***Edited by Moderator Marije to add Product and Version***
Use the Pega default harness(when you are creating a case type default section and harness are created in the UI pages). Save as that Pega default harness and add your section to that one. try it. It will work.
- What version of Pega Platform?
- Any additional Pega Products?
- What design system are you using? UIKit, Theme Cosmos, or Constellation?
Please verify the modal button (pzModalButton) has not been modified or replaced in any way?
pzModalButton is an autogenerated control and is configured to work specifically with Modal dialogue boxes and it should not be modified because:
- It is a Final rule (pz)
- pxButton cannot replace the OOTB pzModalButton in a Modal dialog box
@Anoop Krishna yes, if you use your own harness model submit not work
@Anoop Krishna yes, we want to make a new Hanas, but we don't use save as .
