Hopkins Software Pvt. Ltd.
Last activity: 20 Mar 2023 6:59 EDT
How to Update customer Detail different screen properties?
Hi Everyone,
My requirement is how to update my required 1st 2 screens properties that properties filled in left side in read only mode in first column. 2nd column having Update check box if I click Update all check with respect properties are selected then 3rd column properties are editable mode. If i Update Details immediately update the details and results are reflected to respective properties. How to do this please tell me? please check Below images
After Select check box respective fields are editable. If select Update check box all check boxes are selected then all properties are editable I was changed Language preferences properly test and press tab
Hi Everyone,
Left side property value also changed to test
Like above Written Language is changed
