Tata Consultancy Services
Last activity: 7 Jul 2022 11:55 EDT
Giving different label for the property conditionally
I have requirement for one of the field in Modal window should have different labels conditionally meaning if condition met, property label will be Name(XYZ) and if not, label will be Name(ABC), but the property is same only.
I have put the same properties two times in the section with different labels and with visibility condition, but while closing the modal window, values are not saving properly.
Can anyone please help with how to achieve the above requirement?
Nirmala J
@NirmalaJ2240 Have you tried unchecking the "Run visibility condition on client" under the visibility condition?
