Sun Life
Last activity: 24 Feb 2023 13:58 EST
Ruleset not showing up in Localization Wizard
I have my application ruleset name as “RULESETNAME_XX” and when I run the wizard, Pega is not showing this ruleset in the list rulesets to select for localization. I am thinking Pega may be skipping this ruleset by assuming the 2 chars (_XX) as localization ruleset. Can someone suggest how this can be addressed.
Krishna
***Updated by moderator: Lochan to update platform capability***
Updated: 24 Feb 2023 13:57 EST
I reviewed the behavior on my 7.3.1 system. You are right about the ruleset being filtered because it is treated as a localization ruleset. The pzAddApplicationAndRulesetsToStack activity has the following when condition in one of the loops and exits the iteration to add that ruleset if it is true.
@(Pega-WB:RuleManagement).IsALocaleRuleSet(@whatComesBeforeFirst(<CURRENT>, ':'))
I see there is an 'Include field value from other rulesets' section in the localization wizard. You could try adding the ruleset to your access group and selecting it here.
CollabPartnerz
Could you please provide detailed steps of adding that syntax.
I am not suggesting to add any code. I was pointing out the code that looks like it prevents that ruleset from being displayed. My suggestion is to try adding the ruleset on the access group as a production ruleset and then select it in the 'Include field value from other rulesets' section.
Similar use case for other customer (please refer HFix-41580 created from Pega 7.2.2), please try to suggest same if it works. Please create an SR with Pega GCS to obtain this HFix.
Sun Life
Thank you. I think I need to create a SR to get the HFix.
![](https://accounts.pega.com/sites/default/files/styles/user_image/public/2023-07/f7f35052-5e7d-4ed9-ada9-87594f1d3c63.png?itok=bz3Ms_gZ)
Hey @KrishnaK8747,
Please let us know the SR when you open it so that we can track this for you!
Thanks!
Sun Life
Hi MarissaRogers, Very much appreciated for the help, This is my SR ID : SR-C66507
John Paul Raja Christu Raja
![](https://accounts.pega.com/sites/default/files/styles/user_image/public/1689951000/acf9b3f6-41e7-4ef2-9e55-8da39714b54f.jpg?itok=JYQYUbWS)
Thank you! I've connected this post to your SR.
![](https://accounts.pega.com/sites/default/files/styles/user_image/public/1689875000/64a627d8-9c24-4a5c-9e34-53733b360490.png?itok=_Z7lAPqa)
Just to clarify - there is no HFIX-41580. This is not a formal hotfix developed for this scenario because this was not assessed as a BUG in the product.
What was suggested to the customer and confirmed working in the previous SR involving this issue was the below -
"When rule in the following rules (PegaAccel-Task-Localize. pzAddApplicationAndRulesetsToStack as well as PegaAccel-Task-Localize.AcquireHTMLParagraphs) were commented via privatecheckout before running the localization wizard to allow developer's ruleset that had a suffix of underscore '_'. "
So you will need to apply this solution first and let us know your feedback.
Sunny
Sun Life
Hi Sunny,
Thanks for the quick fix and I thought of this solution but not sure how Pega behaves at run time when French ruleset is created for the rulesets (Rulesetname_xx) like Rulesetname_xx_fr with this solution. I am doubtful this french ruleset will be recognized by Pega at run time.
Hence if Pega can provide any fix, would be helpful.
Hey Krishna, the solution provided was tried out and confirmed by a customer that is why I offered the same to you to unblock you from your development blockers, since it is a private checkout you should try and give this a shot. We can check with Engineering if they don't mind giving the same fix as a hotfix but like I mentioned before it was not categorized as a BUG in the previous scenario so I'm not sure of the outcome this time around. Thanks.
Scotiabank
Thanks Sunny. I am able to see the ruleset with the private checkout solution and run the localization wizard. Also tested the application and end to end is working perfectly.
Thank you all for your support.
Alla Stretovych
That's good to hear Krishna.
Can one of the Community Moderators (Marissa), for its worth, please spin off an enhancement request to accommodate this requirement in the product itself for any customer in a future release of Pega. You can mention the SE# mentioned in this post. Thanks.
I have submitted this as an enhancement through our internal system and updated the FDBK ID in the original post. Please take this FDBK ID to your Account Executive for next steps.
Thank you!
![](https://accounts.pega.com/sites/default/files/styles/user_image/public/1689954000/f7151e69-7bd9-4702-be03-ebb6f0beb05f.jpg?itok=GWX3Wdig)
CollabPartnerz
Please find the below link might help you
Maradana RaviKumar
