PEGA Branch Ruleset Merge Wizard Fault
While i am doing the development and then try to merge branch ruleset back to Application RuleSet, sometimes it will get failed without an error message in the Merge Wizard.
I'm on PEGA 7.2.2
Here is WARN and ERROR in the log file:
WARN - Required parameter'TargetRuleSetName' for data page 'D_pzMergeVersions' cannot be blank.
ERROR - Exception caught while evaluating when
java.lang.ArrayIndexOutOfBoundsException: 0
at com.pegarules.generated.pzRuleSetNameIsABranch_071017__r0ECi0EdVafz5796VRmFw.pzRuleSetNameIsABranch07_10_17(pzRuleSetNameIsABranch_071017__r0ECi0EdVafz5796VRmFw.java:107)
And When i checking the Activity "pzOpenAllSourceRuleSets", i seems like a significant code fault in one of the step 2.2 while checking the dependent rulesets(ex "pyIsSourceABV"=="true")
Is it a knowing issue and is there a workaround for this since the rule is set as "FINAL"?
