Citi
Last activity: 26 Jun 2019 4:50 EDT
Branching and Merging
In the senior system architect course, under the topic - Branching Ruleset, it is mentioned that there should be separate team application for each team, which is built on top of the main/base application and then the branches should be created on the team application and finally merged.
Why would this be needed? Can we not achieve the same by directly creating the branches in the main application and then merge it using the merge wizard - as instructed/explained in the Exercise lesson as well?
