LTIMindtree
Last activity: 18 Jan 2023 23:54 EST
Populating new Properties added to Index Class (Declare Index) when the source page context is px property(PageList)
I wanted to create a declare index on embedded class and the source page context is pxStageHistory.
I tried to trigger the declare index by changing the stage on the case, but declare index is not triggering and the properties are not populating.
Note: All the index properties are optimized
@kaustubhjain Quickly configured and tested in my local environment and the index class is getting populated without any issues. For benefit of doubt can you test the behaviour by moving /merging the branch rules in to a base ruleset probably 99patch version.
Following the configuration of Declare Index rule:
