Specifications needed for Pega Robot Runtime 22.1
What would be the specifications needed when installing Pega Robot Runtime 22.1?
Please elaborate more on your query? What kind of specifications you have been looking for? Installation side or Post Installation steps?
@Kishore Sanagapalli I mean what is the system and server requirements for Pega Robot Runtime 22.1
Attached the Sample Documents here. You can visit Pega Support Portals for latest versions of Pega Studio and Runtime Installations along with System Requirements.
On a Generic Note, Any Windows Machine / VDI / VM with Windows 10 and above versions along with 4GB RAM as minimum need and 120GB HDD / SSD is sufficient. But if you're looking for specific versions, Please visit the Pega Support Portals.
Note: Please Mark the Solution as accepted, if you the query is answered.
@Kishore Sanagapalli The requirement for Robot Runtime and Robot Studio can be found here:
Requirements for running Pega Robotic Automation
