Ford Motor Pvt Ltd.
Last activity: 23 Mar 2023 23:29 EDT
Robotics 19.1 to 22.1 solution upgrade issues
We have recently upgraded one of the solution which was initially developed in Robotics studio 19.1.118, and upgraded it to 22.1.4.
Following are few hiccups we faced:
1. Earlier we had used numeric expressions in procedure automation, The numeric expression was available in Global container. After upgrading to v22. The solution does not run, and it throws exception at numeric expression while running the solution. After replacing the old numeric expression (global container in v19) with new numeric expression (local scope in v22), the solution is working fine. Is it expected behaviour ?
2. We had used string split method in v19.1, and used Get method (with indices parameter) of String array proxy (output of split method). After upgrading the solution to v22, The get method (1 parameter) got replaced with get method (0 parameter) in V22. And that was throwing exception while running the solution. After replacing the proxy's method again with 1 parameter, the solution runs fine. Is it expected behaviour ?
@Vikas_Agrawal
