Pega Robotics: Universal Web Adapter execution failing with .NET exception
We are facing a .NET exception related to the memory allocation in the Pega Robotics solution execution in runtime environment. We used Universal Adapter in our solution and using UWA we execute our automation for a set of websites. Each call start the UWA and stops once the automation completes. It seems in this repeated process, the universal web sharing service are not properly removed after automation stops or exits.
Appreciate if any thoughts or experiences on this scenaios.
Thanks much!
***Edited by Moderator: Pooja Gadige to add support case created tag***
