Issue with pd4ml in Pega 8.7.3
Greetings. We recently upgraded from Pega 7.3.1 to Pega 8.7.3 and with that pd4ml jar has also been bundled with latest 4.0.13, however when we use the same code, which was working with pd4ml v3, it does not work with pd4ml v4. Having said that i have seen that same classes/methods which are in pd4ml v3 has also been packaged in pd4ml v4. Issues i am facing are the HTMLStream does not display properly, page margins are not set properly and so is the page size/width. Is anyone using this and if so, can you please let me know? I am happy to share the java code if needed. Please note we are not using HTMLToPDF activity, instead using render method from pd4ml to write the pdf as bytes.
Any questions, please do let me know!
Bharat
***Edited by Moderator Marije to add BUG tags***
@KOMARINA this question appears to be a duplicate of your more recent question Custom Page Insets and Page Size when using HTMLToPDF.
Please see the response in that post, as well as the Support Document Updates to PD4ML support
Could you test your scenarios again using Pega 8.7.4 to confirm if the behaviour is as documented?
