John Deere
Last activity: 24 Nov 2022 7:37 EST
BIX Extract doesnt include newly exposed column
We had a exisitng Extract rule. I added one property and exposed it by adding to the data type and changed the length of the same property using system>database>schema tools. I created the same field in the target database with same length as property.
Added this property to the extract rule. While running the extract rule I find that insert into statements are having the property value null.
Can someone please assist?
@PareshN5090 Hi Can you try after resaving the db table instance ?
