Tata Consultancy Services
Last activity: 9 Oct 2023 12:38 EDT
Validate Rule Failure
Hi Team,
I have applied the validate rule in below properties and These properties I have used in the section and this section I have called in flow action.
1. Last Name
2. Date of Birth
3. Age
4. Zip Code
I have enter the value in First Name and Last Name : Pega and PEGA and other fields like Date of Birth, Age and Zip Code I didn't the enter the values, the validation working fine for Last Name, Age and Zip Code, Validation failure in Date of Birth..Even I didn't enter the value also not showing validation error. in other fields like Age and Zip code showing the validation error.
Note: I didn't make it mandatory/required as : DOB, AGE and ZIP code, I made it mandatory/required only for First and Last Name.
Note: I didn't set the breakpoint in Validate rule under ZIP Code Property
Sequence of Steps called the properties
1.Last Name 2. Age 3. Zip code and 4. Date Of Birth
Is this OOTB Working like that only ?
PEGA Personal Edition 8.7
Hi Team,
1. Last Name
2. Date of Birth
3. Age
4. Zip Code
In the above 4 properties, Date of Birth validation not working and Other remaining 3 working fine
Please help me on this?
Ashok
