Cognizant
Last activity: 19 Dec 2022 23:56 EST
Change the Access group portal
Want to update the portal details to make it default
***Edited by Moderator Marije to change type from Pega Academy to Product, added Product details and Capability tags****
T- Systems ICT Private Limited
Hi @CHAYARAVI, Could you please elaborate your issue?
Hi @CHAYARAVI,
Open your operator id ,Open the access group and inside you will have the portals to modify/Change.
@CHAYA There was no other solution, As you need to login to the developer studio and need to change the access group.
v2 value biz solutions
@CHAYARAVICHAYARAVI How to Change from User Portal to Developer Portal. while login I am getting Directly to User Portal, while changing I am unable to login to developer Portal.
Hi @ravit5230,
In the screenshot attached change the access group from pxExpress to Developer.So that you will be able to login to dev studio by default.
I hope this will helps you.
If it helps please mark it as accepted solution.
NCS Pte. Ltd
SG
Hi @ravit5230: I hope you updated the access group to point to user portal as default. And now you are navigated to user portal and not able to switch back to App studio / dev studio.
If this is the case, please reach [email protected] to update the access group.
Refer: https://community.pega.com/get-started/community-edition?
If you have created any application in the trial and added to your operator, check if switch application helps (Navigation pane -> My Applications)
Thanks.
