IBM
Last activity: 23 May 2022 13:01 EDT
Need to develop a application
I need to create two users, one is creater and another one is approver.
Please suggest how to create.
***Edited by Moderator Marije to change Type from Discussion to Question***
Updated: 23 May 2022 13:01 EDT
T- Systems ICT Private Limited
Hi @HimanshuG6705,
Are you asking about fields?
It's very simple, click on approval shape and inside add the fields and you can make the fields as readonly, Auto.
Updated: 23 May 2022 13:00 EDT
Hi @HimanshuG6705,
For this requirement, you need to create 2 operators.
Ex:Let us assume there is Leave Application. Employee and Manager are the two actors involving in it.First Employee will fills the required data and submit the data,then case moves to manager.
You need to add Approval Step and in the Approval step you need to Enter Route to specific user ,by using User name or Operator id you can route it to the manager.
I hope this will helps you.
Surya Prakash Kamineni
IBM
@Kamineni Surya how to create a submitted record view in approver's login.
Hi @HimanshuG6705,
IBM
@Kamineni Surya can you please share your number so that we can connect and close all the issues in one go?
IBM
@Kamineni Surya If multiple records have been created then how to show them in listing in approvers login.
Himanshu Goel
