Pega 30-day trial - How to delete trial case types
it's impossible to delete case types in "My Auto Application"
is there a way to do it using only app studio ?
ragards
ragards
@IsmailB3 Please check your operator access to make sure I had administrative privileges for the particular application.
Try adding both pzSystemOperationsObserver and pzSystemOperationsAdministrator privilege to profile. Check your logs to see if there are any other errors.
Test with other Administrators as well.
If you have further issues could you check the FAQ?
