Pega Upgrade Issue - Migrate Job Stuck
We are upgrading a Pega 8.5.6 Environment (Tomcat + Oracle). Running the 1st Job Migrate.bat. The job is stuck in the below area for over 8 hours.
[java] Fri May 13 09:04:09 UTC 2022 (INFO): Table PR4_RULE is still being moved... [java] Fri May 13 09:04:09 UTC 2022 (INFO): Table PR_ENGINECLASSES is still being moved... [java] Fri May 13 09:06:09 UTC 2022 (INFO): Table PR4_RULE is still being moved... [java] Fri May 13 09:06:09 UTC 2022 (INFO): Table PR_INDEX_REFERENCE is still being moved... [java] Fri May 13 09:06:09 UTC 2022 (INFO): Table PR4_RULE_VW is still being moved... [java] Fri May 13 09:06:09 UTC 2022 (INFO): Table PR_ENGINECLASSES is still being moved... [java] Fri May 13 09:08:09 UTC 2022 (INFO): Table PR4_RULE is still being moved... [java] Fri May 13 09:08:09 UTC 2022 (INFO): Table PR_ENGINECLASSES is still being moved...
All the tables mentioned here are already migrated in the new Rule schema.
But the next tables are not getting updated. Job is not failed.
But only the same verbiage is appearing in log that, these tables still bring moved.
PFA the Migrate Log.
Any idea on this?
***Edited by Moderator: Pooja Gadige to change category from Product to Update, add sub-capability tag***
***Edited by Moderator Marije to add Support Case Details; update capability tags***
