Help needed for a support analyist on pega robot deployed version.
Hi folks, is there a way to check the current deployed version of the pega framework on Citrix ? and can it be downgraded or compatibility set for deployments packages on later versions to be backwards compatible or visa versa.
sadly, I’m upskilling, inherited this mess.
im working on there may be config switches to allow compatibility of for code built on a later framework, make it compatible with earlier versions.
Thanks all the best Cat
