Wipro
Last activity: 4 Oct 2021 12:45 EDT
Runtime vs Studio exe
Wish to check if for the exact same version of openspan. Can I assume that the runtime exe installed in the client desktop is same as runtime exe in the studio
The background to my question is it ok for a Dev to test the automation on a studio and then be sure that the same will work in client environment, assuming all other confirmations are the same.
@SaravanaRajI The version of Studio that you create the deployment with must then be loaded by the same version of Runtime. The easiest way to check is just to look in Add/Remove programs and you can see the version there.
This is a helpful webinar we just completed that discusses how our synchronization server works.
https://collaborate.pega.com/discussion/pega-community-events-top-five-reasons-you-need-synchronization-server
