When will Pega Robotics Studio support version switching like Runtime 19.1.1
The ability for runtime users to switch their version of Runtime based on the Package being run is fantastic and allows us to develop in newer versions of Pega Robotics faster since the upgrade process is much more streamlined.
However, this isn't really the case for our developers and production support team, who still have to manually uninstall/reinstall the different versions of Robotics Studio/Plug-In based on the Robot being supported.
Are there plans to update Robotics Studio/Plug-In so that it works similarly to the runtime? If so, is there a rough timeline for when this would be available?
Developers should not really have to switch versions frequently. If you have a situation where you are going back and forth, you might consider upgrading the older solutions to the newest version since presumably, you are making changes that require testing anyway. Synch Server would make it easy to update the runtime on those machines, so changing versions of the project should really be a matter of testing (which you'd already be going through anyway).
