cognizant
Last activity: 15 Jul 2021 12:55 EDT
Remove a between value in property/ parameter
I have a property/ parameter which populates values as comma seperated like example abc,bcd,fgh.
I need to write a when condition to check if bcd is present in parameter then bcd should be removed and the paremeter value should be now abc,fgh.
Any inputs on how to achive this? I know one approach to use what comes before into a new parameter and what comes after into another new parameter and add these two new parameters.
looking for any different and easier one step solution
