Lloyds Banking Group
Last activity: 2 Jul 2021 4:16 EDT
Scenario testing using Deployment Manager not giving correct results.
We are trying to use Run Pega Scenario Test step in Deployment manager and using CrossBrowserTesting as the service provider. If we run the Test Suite manually from Dev studio it fails (as some of the test cases are failing and Pass percentage is not 100%) but when we are running the same test suite from deployment manager its passing everytime. Also, the test suite is running in CrossBrowser Testing tool but returning a Pass result always. We are expecting it to fail when the test cases included in the suite don't pass and result is not 100%. So, we are not getting correct results for run Pega Scenario test when used in Deployment manager. Can anyone help with this please.
Here is the step config in Deployment manager:
