Unable to install Pega 8.6 personal edition
Hi ,
We are not able to install Pega 8.6 personal edition.Getting follwoing message
1. We have checked the port availability.No issue.
2. After first failure we deleted all the files , killed process and rerun the steps again. But same error.
We tried three times but same result. Is there any specific configuration required for pgsql? It seems problem with pgsql start.
Hi ,
[exec] creating directory C:/Pega/Pega8.6/PRPCPersonalEdition/pgsql/data ... ok [exec] creating subdirectories ... ok [exec] selecting default max_connections ... 100 [exec] selecting default shared_buffers ... 128MB [exec] selecting default timezone ... CET [exec] selecting dynamic shared memory implementation ... windows [exec] creating configuration files ... ok [exec] running bootstrap script ... ok [exec] performing post-bootstrap initialization ... ok [exec] syncing data to disk ... ok [exec] [exec] Success. You can now start the database server using: [exec] [exec] C:/Pega/Pega8.6/PRPCPersonalEdition/pgsql/bin/pg_ctl -D ^"C^:^\Pega^\Pega8^.6^\PRPCPersonalEdition^/pgsql^\data^" -l logfile start [exec] [exec] [exec] WARNING: enabling "trust" authentication for local connections [exec] You can change this by editing pg_hba.conf or using the option -A, or [exec] --auth-local and --auth-host, the next time you run initdb. [echo] [echo] Waiting for Postgres to start...
