TD Bank NA
Last activity: 18 Mar 2021 16:22 EDT
HAZELCAST cluster member IP address
Hi
We have a problem in our implementation(PEGA platform 8.2.2) where AUTO discovery of nodes in HAZELCAST fails. Looking through the HAZELCAST documentation we came across below setting . We are trying to explicitly list the IP address of the nodes which can be routed.
Cluster Members |
initialization/cluster/members |
A static list of cluster member IP addresses, separated by commas Disables automatic discovery |
Not Applicable (user defined) |
<IP 1>, <IP 2>, …. |
Can you please help us with the steps to explicitly define members in the cluster with their IP address?
- Can this setting be incorporated under Dynamic system settings? If so will it override what is in the database?
- Is there any other way of adding this setting in a live environment without having to redeploy PRweb.war
Sri.
