PEGA 8.5.2 & ORA-00933
on Webphere 9, Oracle 11, I've upgraded platform from 8.2.1 to 8.5.2.(typical in-place)
All is started as expected after adding the specific grant - GRANT SELECT ON SYS.V_$PARAMETER to yourDBUser; - https://collaborate.pega.com/discussion/engine-fails-initialize-after-clean-upgrade-pega-851-fixed
Agents are disabled. For testing purpose, I've set up node 1: Search,WebUser,BackgroundProcessing node 2: WebUser, Stream On each node running in standalone or in cluster, the same exception is recurrently raised: DatabaseException caused by prior exception: java.sql.SQLSyntaxErrorException: ORA-00933: SQL command not properly ended (same was occurring with a single Universal node) First occurrence is during the startup itself
[2/10/21 12:55:20:198 CET] 00000098 SystemOut O 2021-02-10 12:55:20,197 [ervice-registry-task] [ STANDARD] [ ] [ ] (l.access.RuleCandidateIterator) INFO - Single candidate rule resolution optimization is enabled [2/10/21 12:55:20:595 CET] 00000098 SystemOut O 2021-02-10 12:55:20,571 [ervice-registry-task] [ STANDARD] [ ] [ ] (rsistence.DatabaseTimeProvider) ERROR - Could not retrieve the database time com.pega.pegarules.pub.PRRuntimeException: PRRuntimeException at com.pega.pegarules.data.internal.sqlapi.exec.NativeSQLListExecutor.execute(NativeSQLListExecutor.java:85) ~[prprivate-data.jar:?] at com.pega.pegarules.data.internal.sqlapi.exec.NativeSQLListExecutor.execute(NativeSQLListExecutor.java:52) ~[prprivate-data.jar:?] at com.pega.pegarules.data.internal.PRDataProviderImpl.executeNativeSQL(PRDataProviderImpl.java:1663) ~[prprivate-data.jar:?] at com.pega.pegarules.data.internal.PRDataProviderForModulesImpl.executeNativeSQL(PRDataProviderForModulesImpl.java:138) ~[prprivate-data.jar:?] at com.pega.platform.serviceregistry.internal.database.persistence.DatabaseTimeProvider.get(DatabaseTimeProvider.java:61) ~[service-registry.jar:?] at com.pega.platform.serviceregistry.internal.database.tasks.FailedServiceCleaner.execute(FailedServiceCleaner.java:62) ~[service-registry.jar:?] at com.pega.platform.serviceregistry.internal.database.tasks.TaskExecutor.execute(TaskExecutor.java:74) ~[service-registry.jar:?] at com.pega.platform.serviceregistry.internal.database.tasks.TaskExecutor$$Lambda$165/00000000A40B5C10.run(Unknown Source) ~[?:?] at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:522) ~[?:1.8.0] at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:319) ~[?:1.8.0] at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:191) ~[?:1.8.0] at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:305) ~[?:1.8.0] at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1160) ~[?:1.8.0] at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:635) ~[?:1.8.0] at com.pega.platform.serviceregistry.internal.PrThreadFactory$PrpcThread.run(PrThreadFactory.java:71) ~[service-registry.jar:?] Caused by: com.pega.pegarules.data.internal.rd.queryexec.ExecuteQueryException: An error occured on executing the query for the report definition - There was a problem getting a list: code: 933 SQLState: 42000 Message: ORA-00933: SQL command not properly ended
-- few more similar lines then start continues ---- [2/10/21 12:55:35:888 CET] 00000098 SystemOut O 2021-02-10 12:55:35,888 [ was60603.bc] [ STANDARD] [ ] [ ] (al.access.InstanceExistsFilter) INFO - Added 165600 entries to the instance exists filter in 25.384000 seconds with a false positive rate of 0.001
Second similar exception during startup [2/10/21 12:59:18:955 CET] 00000098 SystemOut O 2021-02-10 12:59:18,955 [ was60603.bc] [ STANDARD] [ ] [ ] ( external.async.IStartupTask) INFO - Initializing service registry... [2/10/21 12:59:18:989 CET] 00000098 SystemOut O 2021-02-10 12:59:18,976 [ was60603.bc] [ STANDARD] [ ] [ ] (rsistence.DatabaseTimeProvider) ERROR - Could not retrieve the database time com.pega.pegarules.pub.PRRuntimeException: PRRuntimeException
[2/10/21 12:59:19:143 CET] 00000098 SystemOut O 2021-02-10 12:59:19,142 [ was60603.bc] [ STANDARD] [ ] [ ] ( external.async.IStartupTask) INFO - Service registry initialized successfully
etc...
Typical logs then application is up. Then above similar error keeps being printed in logs.
I don't see what could be the reason for this (DB is fine, all grants & synonyms are fine). Issue with database table pr_sys_serviceregistry was already fixed This post is around the same following post but not providing solution: Error Getting Current Database time | Collaboration Center (pega.com)) Any clue?
Thank you
Regards
Anthony
