Upgrade from 8.3.1 to 8.5.2
We are experiencing an issue when attempting to upgrade from 8.3.1 to 8.5.2. We are attempting an in-place upgrade using the command line process. Has anyone experienced a similar issue and found a resolution?
- PEGDATA is the correct schema name
_callDDLUtilityUpgrade:
[echo] Call DDL Generation Upgrade Utility...
[echo] /spga/scripts/lib/xercesImpl.jar;/spga/scripts/lib/xml-apis.jar;/spga/scripts/lib/resolver.jar;
[echo] archive_dir: /spga/scripts/lib
[java] 2021-03-04 10:26:39,338 ( install) INFO - Initializing properties with default values
[java] 2021-03-04 10:26:39,348 ( install) INFO - Setting default Entity Value for pega_enable_nologging = false
[java] 2021-03-04 10:26:39,348 ( install) INFO - Getting database metadata
[java] 2021-03-04 10:27:01,921 ( install) INFO - Reading views from schema "PEGDATA"
[java] 2021-03-04 10:27:02,332 ( install) INFO - Reading procedures from schema "PEGDATA"
[java] 2021-03-04 10:27:02,690 ( install) INFO - Reading functions from schema "PEGDATA"
[java] 2021-03-04 10:27:02,867 ( install) INFO - Reading triggers from schema "PEGDATA"
[java] 2021-03-04 10:27:02,870 ( install) INFO - Creating new XML document builder
[java] Exception in thread "main" java.lang.NoSuchFieldError: REFLECTION
[java] at com.sun.xml.bind.v2.model.impl.RuntimeModelBuilder.<init>(RuntimeModelBuilder.java:89)
[java] at com.sun.xml.bind.v2.runtime.JAXBContextImpl.getTypeInfoSet(JAXBContextImpl.java:431)
[java] at com.sun.xml.bind.v2.runtime.JAXBContextImpl.<init>(JAXBContextImpl.java:288)
[java] at com.sun.xml.bind.v2.runtime.JAXBContextImpl$JAXBContextBuilder.build(JAXBContextImpl.java:1111)
[java] at com.sun.xml.bind.v2.ContextFactory.createContext(ContextFactory.java:154)
[java] at com.sun.xml.bind.v2.ContextFactory.createContext(ContextFactory.java:121)
[java] at com.sun.xml.bind.v2.ContextFactory.createContext(ContextFactory.java:202)
[java] at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
[java] at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
[java] at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
[java] at java.lang.reflect.Method.invoke(Method.java:498)
[java] at javax.xml.bind.ContextFinder.newInstance(ContextFinder.java:171)
[java] at javax.xml.bind.ContextFinder.newInstance(ContextFinder.java:131)
[java] at javax.xml.bind.ContextFinder.find(ContextFinder.java:335)
[java] at javax.xml.bind.JAXBContext.newInstance(JAXBContext.java:431)
[java] at javax.xml.bind.JAXBContext.newInstance(JAXBContext.java:394)
[java] at com.pega.pegarules.data.ddl.SchemaManager.createDomDocFromJaxbDatabase(SchemaManager.java:2058)
[java] at com.pega.pegarules.data.ddl.SchemaManager.createDomDocumentFromDbIntrospection(SchemaManager.java:2038)
[java] at com.pega.pegarules.data.ddl.SchemaManager.<init>(SchemaManager.java:433)
[java] at com.pega.pegarules.data.ddl.SchemaManager.<init>(SchemaManager.java:478)
[java] at com.pega.pegarules.data.ddl.SchemaGenerator.saveCurrentSchemaState(SchemaGenerator.java:501)
[java] at com.pega.pegarules.data.ddl.SchemaGenerator.main(SchemaGenerator.java:1409)
2021-03-04 10:26:37,170 ( UpgradeDataModelImpl) INFO - Installed Product Versions:
2021-03-04 10:26:37,171 ( UpgradeDataModelImpl) INFO - {Instance: PEGARULES PROCESS COMMANDER!8.3.1, Upgraded from version: null, Build name: PRPC-8.3.1-369} (current version)
