Last activity: 24 Oct 2020 9:26 EDT
BIX Extracts JDBC connection with SSL Port to Oracle Database
Would like to know if anybody has performed BIX Extracts generation via SSL Port which means using secured JDBC connectivity.
Kindly let us know the procedure followed if any, as we don't see any procedure available for secured JDBC connectivity for BIX extracts generation.
I am aware of some clients using secure jdbc connection with Oracle, the question is really for Oracle as it should be transparent to Pega, there should be a lot of docs available from Oracle... Check with your Oracle DBA... For example, here is an example: https://blogs.oracle.com/dev2dev/ssl-connection-to-oracle-db-using-jdbc,-tlsv12,-jks-or-oracle-wallets
