NASCO
Last activity: 1 Oct 2019 5:01 EDT
BIX 8.2 unable to extract to target database with exception
We run BIX from command line and write it into DB tables. We upgraded from 7.1.8 to 8.2 and we have no issues in our 7.1.8 with the same configuration.
When executing the command we are getting below exception.
We have database instance name with JNDi name mentioned in the rule.
We have target database information in prconfig file.
We were able to load the data when run from designer studio with out issues.
ERROR - Encountered bad Data-Admin-DB-Name definition
com.pega.platform.datastore.ConfigurationException: Data-Admin-DB-Name "PegaBIX" has both a JDBC URL ("jdbc:db2://111.1111.111.11:11111/#######:currentSchema=BIXSTG;fullyMaterializeLobData=true;fullyMaterializeInputStreams=true;progressiveStreaming=2;progresssiveLocators=2;useJDBC4ColumnNameAndLabelSemantics=2;") and a JNDI-named data source ("jdbc/PegaBIX") specified (either in the instance or in prconfig)
at com.pega.platform.datastore.connection.internal.config.jdbc.JdbcConfigurationFactory.validate(JdbcConfigurationFactory.java:366) ~[datastore.jar:?]
at com.pega.platform.datastore.connection.internal.config.jdbc.JdbcConfigurationFactory.getDataSourceConfiguration(JdbcConfigurationFactory.java:69) ~[datastore.jar:?]
at com.pega.platform.datastore.connection.internal.config.jdbc.JdbcStore.buildConnectionConfiguration(JdbcStore.java:87) ~[datastore.jar:?]
at com.pega.platform.logicaldatastore.connection.internal.config.ConfigurationMapImpl.registerDbName(ConfigurationMapImpl.java:198) ~[logicaldatastore.jar:?]
at com.pega.platform.logicaldatastore.connection.internal.config.ConfigurationMapImpl.registerDbName(ConfigurationMapImpl.java:140) ~[logicaldatastore.jar:?]
at com.pega.platform.logicaldatastore.connection.internal.config.ConfigurationMapImpl.initializeSetOfDbNames(ConfigurationMapImpl.java:129) ~[logicaldatastore.jar:?]
at com.pega.pegarules.data.internal.store.ConnectionBrokerAdapter.initializeConfigurationMaps(ConnectionBrokerAdapter.java:202) ~[prprivate.jar:?]
at com.pega.pegarules.data.internal.store.ConnectionBrokerAdapter.initializeConfigurationMaps(ConnectionBrokerAdapter.java:193) ~[prprivate.jar:?]
at com.pega.pegarules.data.internal.PRDataProviderImpl.getConnectionBroker(PRDataProviderImpl.java:743) ~[prprivate.jar:?]
at com.pega.pegarules.data.internal.PRDataProviderImpl.getConnectionManager(PRDataProviderImpl.java:710) ~[prprivate.jar:?]
at com.pega.pegarules.data.internal.PRDataProviderImpl.isMultiTenantEnvironment(PRDataProviderImpl.java:1381) ~[prprivate.jar:?]
at com.pega.pegarules.deploy.internal.archive.ParUtilsImpl.setStageDirectory(ParUtilsImpl.java:215) ~[prprivate.jar:?]
at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineStartup.initEngine(EngineStartup.java:526) ~[prprivate.jar:?]
at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineImpl._initEngine_privact(EngineImpl.java:172) ~[prprivate.jar:?]
at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineImpl.doStartup(EngineImpl.java:145) ~[prprivate.jar:?]
at com.pega.pegarules.session.internal.mgmt.EngineImpl.startEngineImpl(EngineImpl.java:249) ~[prprivate.jar:?]
at com.pega.pegarules.session.internal.mgmt.EngineImpl.startEngine(EngineImpl.java:125) ~[prprivate.jar:?]
at com.pega.pegarules.session.internal.mgmt.EngineImpl.startEngine(EngineImpl.java:111) ~[prprivate.jar:?]
at com.pega.pegarules.data.internal.access.ExtractImpl.main(ExtractImpl.java:759) ~[prprivate.jar:?]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:1.8.0]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:90) ~[?:1.8.0]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:55) ~[?:1.8.0]
at java.lang.reflect.Method.invoke(Method.java:508) ~[?:1.8.0]
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethod(PRBootstrap.java:381) ~[prbootstrap.jar:8.2.1-225]
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethodPropagatingThrowable(PRBootstrap.java:422) ~[prbootstrap.jar:8.2.1-225]
at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethodPropagatingThrowable(AppServerBridgeToPega.java:224) ~[prbootstrap-api.jar:8.2.1-225]
at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethod(AppServerBridgeToPega.java:273) ~[prbootstrap-api.jar:8.2.1-225]
at com.pega.pegarules.pub.PegaRULES.main(PegaRULES.java:85) ~[prbootstrap-api.jar:8.2.1-225]
