List of Hot Fixes Available for Pega8.3.4
Could you please find us the list of hot fixes available for Pega8.3.4 instances please? Thanks!
If you have a Pega8.3.4 instance, just run the system scanner. There are internal tools that can be used as well, contact me I will send you the details.
Before raising the question we did hotfix scan in the app system but found none. The question was to double-check and make sure. Thanks very much for your reply.
Support Doc
Support Doc
