Capgemini
Last activity: 30 Sep 2020 14:08 EDT
Delta mode option in Product rule
The description given for the Delta Mode in the product rule varies in two places.
In CSSA content (https://academy.pega.com/topic/configuring-product-rule/v1/in/2866/5371) it says as "Select Delta mode to include only the highest patch version of the application's rulesets in the archive file. For example, if your application references OrderEntry:02-03-05, the archive file produced from the product rule includes only rules in OrderEntry:02-03-05. This feature is useful when you are migrating a patch update."
Where as in the PDN (https://community.pega.com/sites/default/files/help_v82/procomhelpmain.htm#rule-/rule-admin-/rule-admin-product/specify-content-tsk.htm) is says as "To include all version of the application in the product rule, select the Delta mode check box. To include only the current version of the application, clear the Delta mode check box."
Which is the correct description?
