Project unloaded from solution
Hello all,
During developing I encounter a problem when adding a new project.
I have a bigger solution and I want to add a new project. It's an project with existing adapter and automations.
When I add this project and set the references nothing seems wrong. However when the solution is closed and I start the solution again, the project is unloaded and I get the message that the Guid Format is not recognized. This keeps reoccuring.
I added some screenshots.
the project is still existing in my files, however all the folders are empty
Does anyone know what I should do?
Thank you!
Marlot
***Edited by Moderator: Pallavi to change content type from Discussion to Question***
Have you manually changed the GUID of the project? If you edited it manually, that might explain why it cannot load properly. Can you open the project in its own solution?
