Corebridge Financial
Last activity: 28 Jul 2020 15:17 EDT
Need to understand what Pega changed in 8.4.1 Work-.GenerateID activity
1. We have two QA environments STG1 and STG2.
2. STG2 was cloned from STG1 and upgraded to Pega 8.4.1.
3. The pyLastReservedID in STG2's pc_data_uniqueid table shows a value of 12800. However I see cases generating with ID's like CF-8000 (which doesn't exist in STG2).
4. Also note that 8000 appears to be a random number, there are no cases in between range of 6000 to 8000
5. If I do a Private Edit of Work-.GenerateID of 8.4.1 and replace the java with 8.1.5 GenerateID code - it starts generating ID's from CF-12801
Wanted to understand what changes did Pega do to Generate ID in 8.4.1 ? Thanks.
***Edited by Moderator Marissa to update Support Case Details***
