Wells Fargo Bank
Last activity: 23 Feb 2021 22:43 EST
Unable to trace agent run in Pega 8.4.1
Receiving an error when trying to trace an agent after upgraded to Pega 8.4.1
Unable to trace agent run |
Worked fine in Pega 8.3.1
I have the necessary role: PegaRULES:SysOpsAdministrator
Also no popup blockers.
***Edited by Moderator Marissa to update Support Case Details***
FR
How about if you use an OOTB OperatorID?
Wells Fargo Bank
Although I cannot update [email protected] because of organization restriction, i cloned that id and used that.
However, that did not help either.
Hi Sagar,
Did you try with Trace next Run? I think that way you will be able to trace the next run of Agent.
Wells Fargo Bank
Yes, tried that option and others(Trace Now, Trace Next earliest run) too but no luck.
Deutsche Bank Operations International (DBOI)
I am facing same issue in pega 8.4.0. Do we need to raise SR for this?
Wells Fargo Bank
I did raise an SR for this and I was told that this is a product issue and has been addressed in Pega 8.5 or will be addressed in later versions of Pega 8.4.
Hi @SagarS89
Could you share the Support Case ID you opened for this so that I can connect this with it?
Thanks!
Marissa | Senior Moderator | Pega Collaboration Center
Wells Fargo Bank
Sure, that would be INC-141259
Thanks!
Wells Fargo
@MarissaRogers We are also seeing similar issue in 8.4.2. can you please provide us the HFIX associated with incident
INC-141259.
Chiranjeevi Majeti
PL
Fixed in Pega 8.4.3 patch release.
